RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
I recently got an e-mail from Adrian (CH Ignitions)
He will soon have sngle module, single hall sensor CDI for 5 & 7 cylinder radials. Similar to the sytem used on the new Saito FG84 3 cylinder radial gas engine, but W/an easier to set up/adjust set screw applied trigger magnet ring.
Get 5% or more additional HP while using 20% less fuel.
Easier starting, lower reliable idle RPM & all around better user friendliness. No more dropped cylinders & the system is not any bulkier or much more in price than a quality on board glow sytem W/vastly improved relibility.
Nitro can be eliminated completely W/O affectig user friendlyness.
