RCU Forums - View Single Post - Tip Stall
Thread: Tip Stall
Old 05-19-2013 | 10:19 AM
rgburrill's Avatar
rgburrill
Default RE: Tip Stall
ORIGINAL: Bozarth
ORIGINAL: essyou35
?? G force doesn't make you maintain level flight. As for the rest of your post no idea what you are saying.
Oh, but it does. A tad shy of 2 g's at 60 degrees of bank and you will descend. A tad too much pull (more than 2 g's) at 60 degrees and you will climb. Trigonometry at it's finest.
Kurt
It all depends on the angle of thrust. One can make a "level turn" at 90 degress bank with enough up thrust. And depending on how hard you pull the elevator you can get a 2G turn or a 9G turn.
It's all about the forces on the aircraft - ALL OF THEM.
