RE: AMR Trainer 26
Thanks for the comments Cando. Today The plane flew better with more down thrust added last night. Today we discovered that the plane would climb under full power, but was fine at half throttle or less. It was determined the wing incidence was off a bit. With no materials on hand to raise the rear of the wing, I used 2 plastic pop bottle tops under the wing...perfect until a permanent fix can made. Plane slows nicely with the flaps deployed. I also switched to an 18 x 8 prop today, easier on the batteries.lumpy
