RCU Forums - View Single Post - Set up help????
Old 05-20-2013 | 06:44 AM
rrritchey
Default RE: Set up help????
Hi,
We make an IgnitionReg. It should connect directly to the ignition.
ORIGINAL: 1bruno
I'm running a eq6 with two 2700 lit ion bats and I have a ignition cut off. What I'm doing is changing the ignition bat to a 2700!lit ion from a Nicad bat and I need to use a regulator how should I set up your ignition regulator with my current set up? I don't want to have to buy your regulated ignition system I want to use the stuff I have .
