RE: Engine mount
Go with an APC 11/6 after you break it in
That size prop offers the most torque ( for vertical ) and helps with throttle control on your final ( prop drag slows the aircraft )
RULE larger prop with less pitch , that keeps you in the top end recommended RPM range of the manufacturer
