RE: Help Starting .40 SuperStar
What kind of radio do you have?
Yes you use both airleons and rudder to turn the plane, althrough if your teaching yourself, it is much harder to do a good equil turn using both so your turns will be wide and ugly. A rudder is more or less really important for a twin more than a single so some people rarely touch the rudder but its good practice to use it anyway. I dont suggest using your plane in your "neighborhood" find a deserted parking lot or a large LARGE FLAT field if you are going to teach yourself. Although i really dont recommend you do teach yourself. If you use a trainer you will learn faster with less chance of screwing up. Balance checks are all over the place. Just type your question in a search engine, or on here and im pretty sure you will find your answer.
One last comment on the engine break in period. I think these days with the newer engines especially the so called "break in period" is highly over rated. Just run the normal fuel through engine and use a slightly smaller suggested prop for the first flights and thats all you really need to do. Oh and if your going to crash, dont go nose first.[&:]
