RE: Comp ARF BAE Hawk build thread
Finally starting to look how i want it to look!
Not easy getting the decals on but a bit of patience works wonders!
Hoping to get the back end sprayed in colour this weekend..
Alan
Note the green tubular greenhouse, theses are perfect for a spray booth set up as they retain the heat and even better they are not expensive. Paid £50.00 off web, currently £64.00 make sure you go for the ones with 25mm tubing as they will take the weight of the fuselage for hanging etc stops all the bugs and flies but have hung up a fly trapper to get the odd blighter also remember to use full air fed mask when spraying inside the 'booth'
Size is 4m x 2m x 2m
