RE: Flutter
Hi!
An easy fix if you don't ant to mass balance the ailerons is to cut off the outher part of each aileron (10-15cm)at the tips and glue that part to the wing.
Flutter occurs at the wing tip and as such the ailerons should never, never go as far as the tip of the wing!
