RCU Forums - View Single Post - funstar 3d?
Thread: funstar 3d?
Old 05-26-2013 | 05:53 AM
  #54
t-max97's Avatar
t-max97
My Feedback: (9)
Default RE: funstar 3d?
ORIGINAL: raydar
ZacharyR,s suggestion of getting a large 3d profile foamie from rcfactory is the best advise on here if your serious about learning 3d and specially so if you are on a budget.
Sure a 3dhs slick will 3d but a $1000 dollars plus setup will seriously slow down your learning curve by the fact you cannot afford to crash that setup, and crashings part of learning 3d. If you are on a budget what are you gonni do if you do crash your 30cc plane, can you afford to replace it straight away?. foamies are long lasting and even when they are worn out they are cheaply replaced.
Save for your 30cc (go straight to a 50cc if you can) for next year, get a foamie for this year.
I fought against owning a foamie for ages, but they really are the best 3d learning tool.
I wouldn't be 3ding the slick until I was very comfortable with 3d and had learned on something as you and others suggested, I still want to save for one but I can also get a foamie, or I could get a mojo and save for the slick while i'm flying it. Thanks for the advice!
