RE: lipo battery charging ??
Hi brian
what you say in setting up is exactly what i do..and all my 11.1v 3c have charged to 12.6. but i cannot set the amp much higher than 0.5 or i get error and cuts off i can not set as i am being told to do (set the AMP value to the 1C value of the pack as I indicated. e.g. 2.2A for a 2200mAh pack, 4.2A for a 4200mAh pack etc.)what you said here is what i am doing [color=#990000]After you press enter and select Lipo Charge and press enter again the lower left number will flash (0.5a) and you press the right arrow to increase the amperage number. Press enter again and the lower right number starts flashing (11.1 v) pressing the right arrow changes the pack voltage (or number of cells) such as 11.1, 14.8, 18.5 , etc.... The press and hold enter to verify pack and after confirmation press enter again to start the charge.[/color
ok will read the info again you sent sorry to bug you again lol i will get there in the end lol
