RCU Forums - View Single Post - lipo battery charging ??
Old 05-26-2013 | 10:05 AM
opjose's Avatar
opjose
Default RE: lipo battery charging ??
ORIGINAL: bondspyguy
yes brian i can change it but if i set it say to 2.2A for a 2200mAh pack or 1.8 for a 1800mah pack it cuts of and i get the message input err
When does it cut off?
When you change it to read 2.2A ?
Or does it cut off when you start the charge?
If the latter, the packs are damaged and the charger is detecting the incorrect voltage input from the packs.
This means that the packs were over discharged and are effectively ruined.
