RE: servo screws
It depends on what the servo arm shaft is made of. The servos with plastic output shafts generally use a screw with sheet metal type threads. The ones with metal gears/shafts use machine screws. Futaba servos use 2.5mm on the metal gear/shaft.
Bill
