RE: Eindecker EIII
The 'turtle is running' report.......
The fire wall has been drilled for the Zenoah 445 and epoxied into place.......hardwood triangles have been epoxied to the back of the firewall.......the hatch has been fitted to the fuselage .....I glued the hatch locating dowels to the firewall and drilled for the screws which hold the hatch in place.
I also changed the switch mount from flimsy plastic to a plywood base.
Next up is to fit the throttle pushrod and the choke rod to the engine.
I think I can see the finish line - that rabbit ain't go nothin' on me!
(I'll post pictures later when the site allows)
