RCU Forums - View Single Post - Strange Glow Problem (fuel?)
Old 09-21-2003 | 09:27 PM
Pjtg0707
Default RE: Strange Glow Problem (fuel?)
Assuming you are using fresh fuel:
Did the engine tend to konk out at the beginning of the throttle or the end (wide open) ?
Did you adjust your idle with the plane right side up or upside down?
How was your transition? Is there a difference with the engine is right side up or up side down?
If you open the throttle slowly up and down, one click at a time, was there any sag in rpm or even konks out after a few seconds? Was that with the plane right side up or up side down?
Looking at the plans of the US+, the carb centerline with an upside down engine is quite a bit lower than the tank, and the tank is pretty far back from the firewall. I am assuming you set up the plane per US+ plans.
