RCU Forums - View Single Post - header length for pattern - max RPM or not
Old 05-27-2013 | 10:30 AM
rcjunkee
Default header length for pattern - max RPM or not
so in my previous post regarding post flight questions for the Minare Cees mentioned that tuning my pipe for max rpm may not be the best policy for pattern. The idea being I'm looking for consistent pull under load going vertical as well as in a straight line.
Please share with me you insight regarding how to cut my header for pattern.
I have a macs quiet pipe on a Webra 50. It is currently cut to turn an apc 10x7 at 15,500 , max RPM.
I can always however get another header or even put a coupler in to lengthen the header for less RPM / different prop / etc.
Please share thoughts.
thank you
