RCU Forums - View Single Post - Giga Control
Thread: Giga Control
Old 05-27-2013 | 11:22 AM
oistein's Avatar
oistein
Default RE: Giga Control
Hi,
I can read the data without problem. Just go to weatronic.com and download the gigacontrol and install it again. You will get a newer version, i'm sure that is the problem unless you can confirm that you have gigacontrol version 2.59.
I see that you use firmware version 2.50, which is ok. I would however recommend to upgrade to the newest version on the receivers and TX module. I know there has been a lot of changes previously, but no updates last year so it is pretty stable and good now.
By the way the, the data seem very good. A strong link, although dropping a few telemetry packets here and there.
Change:
Ok, then try to uninstall and then install again. Don't know what that could be, but i can read it without problems. Please tell me how that turned out. The other option must be filesystem error, but do you read it directly from the card or copied to the pc first?
