RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 05-27-2013 | 01:50 PM
  #1227
Dave Wilshere
Default RE: Comp ARF BAE Hawk build thread
ORIGINAL: Zetti
Dave, what is the minimum distance between the tailpipe and the elevator servo plate? Is it okay, if the tailpipe sits on the rear former of the servo plate construction, or should there be a minimum gap?
I have fixed my turbine mount below the rails which gives an perfect alignment of the turbine and the tube (sitting on the former) with the thrust line going through the middle exactly (measured with a laser).
Stephan
The cool wall outer (ali) can touch the plate. I've even done one where I lightly dented the outer tube to give more lift in the tube.
Dave
