G-38 Conversion to CM-6 Plug?
I would like to convert my magneto equipped G-38 to a CM-6 spark plug so it will fit inside the cowl on a scale plane. I already have the adapter for the plug but the original plug boot does not fit the CM-6. Can the plug lead just be pulled out of the coil and the boot end replaced. Will the engine run ok with a CM-6 plug? Has anyone done this?
