RCU Forums - View Single Post - G-38 Conversion to CM-6 Plug?
Old 05-28-2013 | 04:18 AM
STUKA BARRY
Default RE: G-38 Conversion to CM-6 Plug?
Agaperacingandhobby.com out of Richmond VA.has a complete RcXcel ignition that will convert your mag to ignition. This conversion is easy to do and will reduce some of the weight associated with mag ignitions. As stated above, you cant just change the plug, the whole assembly needs to be installed.
