RE: G-38 Conversion to CM-6 Plug?
another option is to use a 5/8" hex taper seat plug like the NGK BMR6F.
by cutting off the threaded post and using a small conical spring in the cap to make contact with it you will come out shorter than a CM-6 with adapter AND it is a resistor plug.
