RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 05-28-2013 | 06:04 AM
  #1233
Dave Wilshere
Default RE: Comp ARF BAE Hawk build thread
ORIGINAL: Zetti
<span style=''background-color: rgba(255, 255, 255, 0);''>@husafreak - you wrote you are going to mount your turbine above the rails. Does above mean with the fuselage in a upright position and therefore below the rails in the often shown upside-down position of the fuselage (like in my picture in post #1224)? I have to ask again because I'm a bit confused about the wording ''above'' vs. ''below'' right now.</span><p class=''MsoNormal'' style=''margin: 0cm 0cm 0.0001pt; ''><span lang=''EN-US'' style=''background-color: rgba(255, 255, 255, 0);''><o> </o></span></p><p class=''MsoNormal'' style=''margin: 0cm 0cm 0.0001pt; ''><span lang=''EN-US'' style=''background-color: rgba(255, 255, 255, 0);''>@Dave - many thanks for the information, so it should be okay to set the tube on the former.<o></o></span></p><p class=''MsoNormal'' style=''margin: 0cm 0cm 0.0001pt; ''><span lang=''EN-US'' style=''background-color: rgba(255, 255, 255, 0);''><o> </o></span></p><p class=''MsoNormal'' style=''margin: 0cm 0cm 0.0001pt; ''><span lang=''EN-US'' style=''background-color: rgba(255, 255, 255, 0);''>Stephan
<br type=''_moz'' /></span></p>
Above the rails fuselage upright. Below the rails looking through the wing opening
My tube is hard against the mount for the last 4 years.
Dave
