RE: Redesign/build FEJ
You should see how semis are made. Plasma etch is not such a kind environment.
The issue often raised with electronics is alpha particle hits on memory arrays and flipping a bit in unprotected caches while its on.
With devices off, there will be no issue.
Although these days, the latest programmable digital servos have a bit of non-volatile memory. At most could warrant a re-programming if necessary.
