ORIGINAL: dubd
ORIGINAL: PhilYabelli
ORIGINAL: k_sonn
Not saying manufactures shouldn't be responsible for the quality of the products they sell, but if you can't afford to lose everything you've put into an airplane, then most likely you're financially in over your head regardless of what causes the crash or what you fly. Remember, this is a hobby and the cash you put into it is disposable.</p>
Kirk</p>
Yes...but the question is specific, in this case. If your airframe has a failure, is it reasonable to expect the airframe manufacturer to replace the engines too?
How about we start with the manufacturer just replacing the airframe?
You have plenty of other threads going about your complaint. You can post more about your issue in those many other threads. You really don't need to derail every thread with your issue. Thanks.
The question is simple. What is your position.
