RE: Thoughts and ideas regarding gyro on ailerons
I guess it depends upon what the airplane is doing when banked. I think TP is correct, the nose is probably yawing some what in the opposite direction (adverse yaw) and therefore the gyro used on rudder should be in effect a yaw damper and help coordinate the turn. this is certainly true on full size swept wing transport type airplanes.
