RE: header length for pattern - max RPM or not
great article...can't wait to try the techniques mentioned....
One more thing I thinking about is once the length is correct, where to set needle on the ground.
I'm sure this will be yet another thing that gets worked on in the air but as a starting point common sense tells me to set it where it rich of max rpm with nose up.
