RE: Please help me with my gearbox problems!
Walt:
On the first two "flights" I felt that I may have had a minor prop strike, although there was no visible damage to the prop. I realize that any pressure on the prop, no matter how slight, will probably cause the cheap plastic spur gear to strip. On the third "flight" I held up elevator as I accelerated throught the take off in order to avoid a prop strike. This "flight" lasted only slightly longer than the first two.
I really have no idea on how to program the ESC for a "soft start". I would think that the factory recommended setup would be able to withstand a full throttle take off, but maybe not?
I plan to order a gear box from MAXX PRODUCTS, as soon as I determine which one will fit my motor. I have two more of the gear boxes coming from Horizon which I will return. Trying those again will just be throwing good money after bad!
I greatly appreciate your input and advice, Walt!
Regards!
