RCU Forums - View Single Post - Yellow Aircraft Stingray
Old 05-31-2013 | 12:40 AM
mr_matt's Avatar
mr_matt
My Feedback: (10)
Default RE: Yellow Aircraft Stingray
ORIGINAL: StephenUK
Hi all,
Thanks all for the info, much appreciated. I will put the Wren in it.
Can I ask how I go about using the rudders as air brakes?
Matt would you mind posting a picture of your running gear installation?
Thanks again
Steve
Hi Steve,
Here is a pic, and a link to a thread I did on some of the install back 7 years ago.
http://www.rcuniverse.com/forum/m_37...tm.htm#3721953
For the rudders/airbrakes, you just put them on 2 separate channels (the nosewheel will need its own channel too) and mix an air brake function on a knob or switch that pulls them in together. They are surprisingly effective with very little pitch change. I had them canting out on the Bobcat and it almost made the plane stop in air.
