Hi Rajesh! Sounds like you're ready to do some reading on the wonderful world of SPADs!
A good resource is
www.spadworld.net. Then RCU has a SPAD section with a lot of info:
http://www.rcuniverse.com/forum/forumid_178/tt.htm RCGroups also has a good SPAD section:
http://www.rcgroups.com/spad-simple-...e-designs-176/<div>
</div><div>Looking at your specs, I doubt seriously you're going to be able to get a plane of that size off the ground with a .45 engine. You're closer to the size of the Ultra Spadstick which most guys fly with a 45cc gas engine. Check out the Debonair:
http://www.spadtothebone.org/PDF/Debonair.pdf It is an easy to build .40 size trainer and the instructions on the web site are great. Hope this info is some help. Welcome to the addiction!
</div>
