Computer power supply
Hello gang.
Rigging a Turnigy Accucel-6 50W 6A and would like to use a 400 watt 15 amp computer power supply.How do I hook it up?
I have a yellow wire that supply's 15 Amps (I am told it is ok to use).I just would like the info or wiring diagram on how to use it with the charger.
What is the minim amp out put I need to run this charger?I have other power supply's..
Thank you for your help
