RCU Forums - View Single Post - SBS-01V Voltage Sensor problem
Old 06-01-2013 | 05:52 AM
Rune
Default RE: SBS-01V Voltage Sensor problem
If you have the conector that fit in the reciver ..the smal white one like on my link..you can conect that direktly to the sourch you want a read out from ..I have no other than a cabel direct from the uregulated side off the digiswicths to the rx..I think it only a diode to prevent you from conect wrong polarity.
You must have the conector from your Futaba sensor try to conect on the sourch directly
