ORIGINAL: apereira
As I looked at the manual, I think you either have a cold weld or a bad sensor, did you installed the fuse? If there is no fuse, I think is a bad sensor as I am pretty sure you know how to solder well.
Regards
Alejandro
Hi Alejandro,
Yes I installed the fuse.
About a cold weld, I usually try to avoid a cold weld.
Without any load the sensor reads the battery voltage perfectly, in this case do you think it still can be a cold weld?
Best regards,
Isaac Najary
