RCU Forums - View Single Post - SBS-01V Voltage Sensor problem
Old 06-01-2013 | 06:46 AM
Silent-AV8R's Avatar
Silent-AV8R
Default RE: SBS-01V Voltage Sensor problem
What voltage are you seeing on your transmitter under the RX voltage? This is the one that the servos see, not the one the SBS-01V is reading? Also, do you have the SBS-01V plugged into the the S.Bus2 port??
Also, how are your telemetry slots assigned? What sensor is on which slot?
