RE: Decathlon 46 getting off Water ?
You should be fine . As long as your floats are set up properly you should come out of the water easily..It will come up onto the step and fly its self out when it is ready...I think you will have more power than you need . I don't know the motor though . A lot depends on the angle of incidence between your wing and floats..
