RE: ZEnoah G-62
Bud:
Here are a couple of things to look for.
The phenolic block between the carb and engine. Make sure it is tight and not cracked.
What is your plugs gap? Make sure it is correct
What fuel mix are you running? 32:1 if best and I wont get into what oil to use here.
I know this sounds odd. However if you or you have a buddy that has a DLE55 that is running good. Swap carbs and see if that helps. (Dont ask me how I know) it does work however.
As a last resort I would check to ensure all your fuel lines are tygon tubing and the clunk is in place with a filter. No glow fuel lines for gas.
Regards
Glenn Williams
