RE: MOKI RADIAL Care and Maintenence
Does anyone know of a good electronic ignition cut-off that works with the Rainbow-tronics ignition module?
I've been using a smart-fly, but getting low voltage blinking lights on the ignition module (low voltage) and the engine is cutting out at higher RPM's (as designed). If I remove the ignition cutoff module, all works fine.
I like having the electronic cutoff, but not if it makes the plane un-flyable!
