RCU Forums - View Single Post - Problems when inverted
Old 06-02-2013 | 02:22 PM
av8tor1977's Avatar
av8tor1977
Default RE: Problems when inverted
Yeah!
As to the other comments, the Walbro is indeed an all position carb. However others have noticed as well that if the carb is mounted on the aircraft/engine so that the metering diaphragm is in a horizontal position, high "G" loads can cause a momentary change in mixture. The Walbro is an "all position" carb, but not necessarily an "all "G" loading" carb.
The only thing that will give you a perfect mixture in any and every possible condition is fuel injection. (Maybe.)
AV8TOR
