RCU Forums - View Single Post - Ziroli Hellcat Construction Question
Old 09-22-2003 | 07:54 AM
rc_heli_flier
My Feedback: (12)
Default Ziroli Hellcat Construction Question
I am in the process of reviewing my Zirloli Hellcat plans before I begin construction, and I have a few questions.
I am going to purchase a kit from Precision Cut Kits, and some of this may become clear after receiving it.
Former F7A that is marked on the fuselage side view (rear of wing fairing) is not shown on any of the template sheets. My assumption is that is identical to the bottom portion of former F7, and should be cut as such. Also, I assume the top cut line on F7 is where the rearward angle begins on that former.
Also, the bottoms of formers F1, F2, F3, F4, and F5 make up the wing fairing. My assumption here is to cut the bottom off of theses formers (except for F1, which is marked) and to tack glue them with a piece of scrap back into position on the former before gluing the formers to the crutch and adding the stringers and sheeting. Cutting these would prove almost impossible, in my opinion, after the stringer and sheeting are applied if not cut in advance.
Let me know if I’m on the right track here.
Thanks!!!
