ORIGINAL: ddennison
Thank you both for your help.
Mike - where can I easily download the correct Tx and Rx firmware updates? Did you get from the Weatronics (europe) site?
Also are you using a newer Gigacontrol?
I should update. I have the older Tx antennae and I didn't want to screw anything up. My UB is running just fine...
DD
I updated everything just a couple of weeks ago from v2.30, it went fine.
One thing to do is save each rx model file in the latest version of gigacontrol before updating the tx and rx, as model files made in much older versions of gigacontrol can't be read by the latest version so they can't be restored to the rx after the rx is upgraded. If you have any micro rx you will need the special cable to attach them to the usb port of the pc. Tx module and 12-22 rx are updated by their micro sd card.
The sequence is:
save rx model file old gigacontrol just in case
update gigacontrol
save rx model file in new gigacontrol
update tx
update rx
bind rx
load rx model file made in new version of gigacontrol
