RCU Forums - View Single Post - Throttle arm
Thread: Throttle arm
Old 06-03-2013 | 12:37 PM
JohnBuckner's Avatar
JohnBuckner
Default RE: Throttle arm
Not all versions of the OS .46 has the same carburetor and there are variations in the way you would make that adjustment depending upon which model. If you see a set screw on the side of a throttle arm ring then you are correct and that is where you would make that adjustment to clear a nose ring or tight fitting cowl.
John
