RCU Forums - View Single Post - Processing Weatronic Data.
Old 06-03-2013 | 02:22 PM
dw_crash
Default Processing Weatronic Data.
Hello Gang,
I was wondering if anyone has fooled around with processing the data from the Weatronics receiver? I have several that include the GPS data.
So, you should be able to process the saved files X,Y,Z co-ordinates, speed information to generate g-load data on the plane. I often wondered how much force we place on our airframes. Using the receiver data, you should be able to calculate the G-loads on the plane.
How about processing the position and current information from the servos? This could, if done right, tell you whether the servo you have installed is adequate for the task or under-sized. It could also maybe tell you whether the mechanical set-up is stressing the servos. This could be valuable from a safety point of view.
Just a few thoughts,
DW_Crash
