ORIGINAL: Sparhawk
Thanks Juan.
My Rabbit is heading to Kerry to have a look it. I think I have a couple issues, and one is a pump that is maybe too tight and needs a breakin, so that the ECU doesn't have to work so hard to pump fuel. The other looks like the setting for burner fuel, and it is just low enough that it is 50/50 on whether it will jump to Switchover mode. Kerry may need to unlock it and turn up the flow rate a little, as there is just not enough to keep the burner lit.
Love the Rabbit and can't wait to have it back.
Dan
I bumped up the pump setting for the burner, just a few points. I got a better start and switch over. Be careful not to increase too much as you don't want flames on the start. Check the manual on how to do this. Also and very important is to make sure your battery is fully charged. Aslo, check with Eric for advise.
