Hyper 8 Wheels Dragging
Hi, I will try and explain my problem as clear as possible.
My Hyper 8 .21 3 Port has began to drag the wheels seems as if they are semi locked as if the breaks are partly applied. The gear mesh started making a strange kind of noise and I thought something was not right. Could it be the clutch is not dis-engaging? I hope people with more experience with these RC engines can advise. I can use it until this is fixed, im hoping something has just came loose the the flywheel or spring or something???
Any ideas thoughts etc would be much appreciated, cheers guys!
