RE: Hyper 8 Wheels Dragging
You need to diagnose through a process of elimination. Check mess and make sure the engine hasn't moved and messed up your mesh. Remove the clutch bell and look at the shoes, look for excessive wear or something inside the clutch bell. Check your differentials to be sure one of those isn't bad or having problems that would lock the wheels up. Lastly check the brake to be sure it isn't applying prematurely or something isn't jammed in there causing it to hang up. You are just going to have to look through it at all those points and figure out which one of these it is through eliminating them one by one.
