RCU Forums - View Single Post - SD10G servo saver???
Old 06-05-2013 | 03:45 PM
wphilb
My Feedback: (10)
Default RE: SD10G servo saver???
A simple trick when switching over is to write down EPAs if youhave a radio setup, then lower them to like 25% each way and then increase until you get what is needed, trying to get to 125% or better to avoid stutter stepping that can occur at low EPA numbers.<div>
</div><div>Whit.</div><div>
</div><div>PS, I learned this step the hard way with a set of Hitec digitals on flaps... I let the smoke out! </div>
