RCU Forums - View Single Post - AMA Accepts Rules Change Proposal in Time for the NATS
Old 06-06-2013 | 09:09 AM
smcharg's Avatar
smcharg
Default RE: AMA Accepts Rules Change Proposal in Time for the NATS
ORIGINAL: drac1
Would motor/engine temp telemetry be considered an advantage?
If for eg. an IC engine temperature climbed, it could indicate a lean mixture which would affect power. If in flight mixture is being used, then the mixture could be richened.
Telemetry concerning temperatures should not be considered illegal. Temperatures should be considered flight safety and does not automate anything whatsoever.
<br type="_moz" />
