RCU Forums - View Single Post - Jetcat SPT5 Turboprop - maximum RPM's
Old 06-06-2013 | 12:29 PM
Carbon-Customs's Avatar
Carbon-Customs
Default RE: Jetcat SPT5 Turboprop - maximum RPM's
ORIGINAL: Jetkopter
Thrust: 55 lbs with 27'' prop at 7,0000 RPM
Weight: 4.9 LB, incl. starter
Length: 15.25 inches
Turbine RPM Range: 50,000 - 165,000
Propeller RPM Range: 1500 - 7000 RPM
Exhaust gas temp.: 580°C -710°C
Fuel consumption: 8 oz per/min at full power
Fuel: Jet A1, 1-K kerosene
I had mine in a turbo raven, if you run the prop too fast it will let you know as the tips go supersonic! Sounds cool but with all that thrust dialing the rpm down should not be a problem
the prop tips dossent go supersonic....
the tips just makes some turbolence which go supersonic, like a whiplash...
