RCU Forums - View Single Post - what glow plug are you using?
Old 06-06-2013 | 05:59 PM
JohnBuckner's Avatar
JohnBuckner
Default RE: what glow plug are you using?
ORIGINAL: tlojak38
that still doesnt answer my question. what heat range does the fox miracle plug operate at?
The Miracle plug was originally intended by fox to be used as a fourstroke plug and is of a medium hot range.
If you do not like your #6 A3 was a former designation and #6 is the current designation, The shorter reach is of no real concern and reduction of compression is negligible. Then consider trying the #7 This is a hotter plug than the medium #8.
John
