RCU Forums - View Single Post - Optotronix Aurora LCU
Old 06-07-2013 | 01:41 AM
modtron
Default RE: Optotronix Aurora LCU
I use mine with Futaba gear, select any the channel I want to use and allocate to my required switch - all of my end point or travel values are 100/100.
I have it set t a 3 position switch.
I have outputs 1 & 2 set as different flash types and output 3-6 set as always on.
When I set the required output channel (1-6) I put my 3 position switch into the require ON position for that light.
Then after finishing and storing, the lights are off when i have my switch in my off position, only lights 1&2 come on in my middle positions and then all are on in my 3rd position.
modtron
Oxford UK
