ORIGINAL: Bax
The 8SG transmitter did not have a trainer output, nor were you able to choose PPM transmission. It was PCM512 only. We do not believe you can successfully convert this transmitter to 2.4 GHz operation.
Not true. Even if you have to strip out the electronics and need to replace the pots you still save the sticks and the case.
