RE: H.L. Pershing with TK-22/Benedini combo
Great job on the tank,like the sound and the smoker, I do have a question each time you started it up i noticed it did not go straight to start but that you had to turn over the engine two more times before it continued to run before you then brought up the rps. I only ask in count that I seen someone else start there tank and it did the same hen he to was showing his acoustic smoker. and the wiring schematics is fabulous. and while I checked out your transmitter setup I might have to check into this setup. I like the way it is setup on your transmitter, It's not much different from how I run my Tamiya's using a Futaba. I like!
